So, After receiving my e-bay bought E-Flight Funtana 300 for a miserable 20 bucks. I proceeded to clone it by making a detailed copy of everything. I set it aside and began making it out of Blucore.
I could have just as easy made it out of EPP, but since it's a little expensive and brittle I desided that the EEP copy should wait. I'll try my luck and practice on FFF.
It's a full fuse 32 inch wingspan. All up weight without a battery came up to 10.10 oz.
Powered by a E-Flight 370 1080kv
and a 12Amp ESC
4-9gram Servos
Could I use a 20AMP ESC?
AUW is as follow..
12.30oz with a Turnigy 1000mAh 2S 20/30C
12.65oz with a Ryhno 750 mAh 3S 20C
12.95oz With a Turnigy 1300 mAh 2S 20/30C
14.40oz with a E-Flight 1250 mAh 3S 20C
It be too heavy if I use the following battery..
15.10oz with a Ryhno 1550 mAh 3S 30C
Pictures to follow....
