RE: KingCat Flaps and Matchbox.
I've read many times that a servo connector is limited to 3 amps but truth be known (and you can put it on the scope and test it yourself) with 20 awg wire the pins at the connector will carry over 7 amps before you get excessive heat build up and a voltage drop across the pins. at over 10 amps it quickly starts to melt the wire insulation but the connector pins still carry the load.
