RE: First crash!
About your electrical problem, I had that happen on a helicopter. I ended up re-soldering the connections and the problem went away. I found that if it happened, then I played with the wires at the connection points, then it would start normally again. The connections looked solid, but I guess they were not, so I resoldered and my problem went away.
