RCU Forums - View Single Post - Problems starting my OS 46 LA
Old 09-09-2009 | 04:36 PM
jbclay21
Default RE: Problems starting my OS 46 LA
Thanks for the advice. Got out this a.m. and tried a few of the bits of advice. Got it running and ran 2 tanks through it. I ran one tank through it with WOT and the needle valve set at about 2-1/2 turns open. It ran just fine. The next tank I adjusted down to about 1-3/4 open. It did well also. WOT my tach is reading about 11,500 rpm and the lowest idle that I can get is about 4,500 rpm. I am running 10% fuel with the recommended 11x6 break-in prop. Do these numbers look alright to you guys?
