engine mounting
If you are mounting an engine using a metal "clamp style" engine mount how can you tell if the engine is positioned correctly? You usually need some side thrust to the right correct? Do you just have to guess? Any help is appreciated. p.s. its a os 46 la going in a tower trainer 40.
