ORIGINAL: dakotanut
NO. As soon as I start it now it wants to just take off. I set the carbs idle and then it will still do it buy die when I hit the brake. I'm wondering if the rod from the servo to the carb is wrong. Maybe those stops on the rod got knocked out of whack or something?
Make sure trim on radio is not turned up. Also try adjusting the spring tension on the throttle rod.
