RCU Forums - View Single Post - Rx battery questions
Old 09-10-2009 | 02:57 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Rx battery questions
Brett,
 How many servos are you talking about?? You have to be carefull when going to a higher voltage pack. Higher voltage does not equal longer capacities. Usually higher voltage will give you more power in the servo as well as faster response times. But most times higher voltage will drain the battery faster. If you want more capacity you want to get a battery with a higher MaH (milliamp hour) rating. This will give you more run time with your system.
Ken</p>
