David,
Ifound fuse jig online a while back. Inever got around to puttingthe protective padding onthe clamps, but it does need it.
http://www.nwrcc.com/viewpage.php?page_id=20
I've used it on everything from a 1/3 scale cherokee fuse, to SPA pattern planes, and now a little Eyelash.
BTerry,
I already have the MachNone wing on the foam wing section of the site. Have had for quite a while. Sheeted wings from 1lb foam is probably the same weight as non-sheeted versions of the injection molded old Ace wings, plus nicer to cover, and a LOTstronger, although I will probably go 1/16" sheeting, very little more weight, and a lot nicer to work with. There is basically no room for sanding mistakes on 1/32" sheeting. Don't ask how I know
Will be putting them up in a bit. Got some other custom cutting to catch up on, then Ican do the pricing. Sneaking the build in while the router is busy cutting kits.
Don
