ORIGINAL: qspilotcmh
Do you normally solder fuel barbs on the fuel tank brass tubing? I have heard you need to cause the line swells over time, and I have also heard to double zip it and it will stay secure.
How many people are using the NGK CM-6 plug?
qspilotcmh,
I have flown a gasser or two in my time and I have never had a fuel line come off. I use to use wire to secure the fuel line but in time it would cut into the line. Now a days all I use is one small zip tie and make sure it's tight. I use the fuel line for two seasons and then I change it all out for new. All the other ideas sound good but I have never had a need to do anything else.
