RCU Forums - View Single Post - Avistar with OS 46FX climbs by itself.
Old 09-11-2009 | 10:09 AM
mxaexm
Default RE: Avistar with OS 46FX climbs by itself.
ORIGINAL: RCKen
You shouldn't have to shim the motor to add downthrust. You should be able to correct the climb by trimming out the plane using the trims on the radio as well as the clevis on the elevator. Simply adjust it so that the plane will fly level.
Ken</p>
I will fly today and see if I will be able to trim it with my radio...is not then I might adjust my elevator...if that won't help...I will add some washers.
thanks RCKen.
