RE: Remote Kill Switch for Magneto engine
Well I'm afraid you're stuck with the method mentioned, the reason you still see magnetos in full scale piston stuff is precisely because the mags don't require any electrical power to operate. So in the event of a power system failure the aircraft engine will continue to run.
Sooo.... the only way to kill a mag is to break it or ground it out.
