RE: New JetJoe J-Junior 4lbs turbine
the fuel lines going to the trubine is 3mm after the fuel pump the fuel pump at the moment the turbines run the fuel pump for the jj1200 with a buy pass in the line as the voltage drop without the buy pass would be to low the flightworks 100b fuel pump works fine and jet joe is in the stage of developing a new pump
ill put some pics up of my set up for you if you wish in close detail
