RCU Forums - View Single Post - 4 Stroke wont run without glow plug
Old 09-13-2009 | 08:16 AM
Rodney
Default RE: 4 Stroke wont run without glow plug
More probably to lean rather than to rich. I use a few of the Magnum 4 strokes and have found that the Fox Miracle plug works as well as any other 4 stroke plug and seems to last longer than the OS's do. Also check for oil content of the fuel, to high an oil percentage could be causing some of your problem. I have also had better luck with the lower nitro ratios, typically 10% seems about right.
