FB,
On the Baby Banshee. the shape isn't the issue, it's the span. It is there in a reduced view, but not full size. If all else fails, I'll mach the Eyelash stab span, since the Banshee basically came from the Eyeball,(Kinda).I'll measure to see if the reduced view of the wing is at the same scale..Duh..
As far as the Mach None canopy, even though it is a carved block, people will want the clear, so I might have to carve one and send to him..
I'll PMya about the Miss Norway, and a few other things...
Don
ORIGINAL: Free Bird
Oh yeah, if anybody has the old plans for the Baby Banshee, or an old kit, what is the span of the stab. The very faded palns I got from Mr. Martin must have been kit plans, as the stab ends are cut off, and there is only a reduced size view of the entire stab. And a canopy I could get copied by Keith at Park Flyer Plastics would be very cool for any of the planes in queston.
Don
Don,
You're in luck for the Eyelash canopy. I sent Keith a canopy several months ago to make a mold from. He should have what you need, just contact him. The MachNone used a block of balsa for the canopy, no plastic canopy for that one. Sorry but I can't help with the Baby Banshee, but given its simple stab shape, you should be able to draw it out. Does the Baby Banshee use the Ace wing cores? Also, are you interested in a 1/2A Miss Norway?
FB
