RCU Forums - View Single Post - CMP 80" Zero Bash*****
Old 09-13-2009 | 12:13 PM
77chickenhawk's Avatar
77chickenhawk
Default RE: CMP 80
About half way in the landing gear section. i lined the area where the gear will be mounted (photos) with 3/16 ply and the landing blocks are halfinch ply.. after the location is set in stone , i'll gusset the blocks to the wing. ill post later. had a friend (on sight signs) print a outline of the real zero and matched up the location for the gear. the thin ply where the wheel is is for added strength just incase the gear slapps the top of the wing. i have about 3/16 clearance but you never know + its there for the fuse, thats where the fuse rides on the top on the wing.
ID:	1274268   Click image for larger version
ID:	1274269   Click image for larger version
ID:	1274270   Click image for larger version
ID:	1274271   Click image for larger version
ID:	1274272   Click image for larger version
