RE: front one way
My lightning EPX pro has a full driftset up. I changed the Spur gear from 58t to 64t for more low end torque.The pinion changed from 26t to 16t.Both front and rear diffsare locked. The motor burned out so ichangedit to the 5.5t EZ run motor and ESC. I need a front one way diff so when i brake, the back end whips outand i can cut turnsfaster. With the front diff lockedits harder todrift tight turns.Can aTC3 front one way fit??? With a few modifications and all??? Thanks in advance.
