RE: Looking for Assembly Manual for Global .46 Size Ultimate Bipe
A two stroke .52 or .55 would be nice.... or a four stroke .72. As for dual aileron servos, that may not be too hard. Look at the lower wing where the servo goes in the center section. Are there lightning holes in the ribs? If there are, chances are the are holes in the outer ribs too. It should not be much of a problem to run leads.... if the ribs are solid, yep, that will take some work.
