RCU Forums - View Single Post - Sebart Wind 110
Old 09-14-2009 | 04:23 AM
  #205
john agnew
Default RE: Sebart Wind 110
Guys
Just a little tip, unless you are flying from paved surfaces or very short grass the wheels are a bit on the small side. As our grass is not too short at the moment I changed the
wheel to 2.5 inch and omitted the spats. I have been told also to omit the shrouds to the landing gear legs as if you do have a heavy landing these will be forced back into the fuselage and do more damage. I did crack my gear plate due to catching a hole but it was an easy fix and I have used better plywood on the new plate and added some re-inforcement.
John
