RCU Forums - View Single Post - Strange problem with Homie 30cc on gas/glow...
Old 09-14-2009 | 10:05 AM
captinjohn
Default RE: Strange problem with Homie 30cc on gas/glow...
ORIGINAL: plasticmaster
Is there any other reason that the engine would run off of the straight gas and oil mix imediately after not running on the gas/glow mix? I'm speaking specifically about the fuel. Thanks for all of the responses.
How long will it run on the "straight gas" and oil mix in that imediately after? I think it is still running on the gas/glow mix somewhat...it takes a couple of min on idle to purge out the fuel the engine was running on first. I have had a engine run on gas/glow for a full min on just a small shot of prime through carb throat, with no fuel line hooked up. Run it longer and Rev it up...see how long it runs then. Hey...get a DLE30....the time I wasted was way too much on gas/glow....just too many hoops to jump with that gas/glow for me. If you like killing time and continually messing around.[X(]..stay with gas/glow. Best Regards Capt,n
