ORIGINAL: danielplace
ORIGINAL: Dockman
Clutch is off not, will fit pipe tomorrow night and if I have enough time I'll hit the pond again. These RCMK motors are some hard starting sob's when cold.
You might be choking the engine a bit too much or something. I have 13 RCMK's and 5 are the new EVO engines and they all start in 1-3 pulls when cold.
What do you have your needles set at. They only need about a quarter pull choke, only the slightest of fuel on the finger and another pull at 1/2 - full throttle and it should be running.
So I need to give it some throttle while starting? I need a third arm to start this thing then?
