RE: WILL I NEED SHIELDING?
I have taken the FORCE ONE and made it into a 60"WS . The aft end on this plane is exatctly that 60" Split down the middle giving me a 30" ELEVON. There is two servos on each up/down unit - 12" up in the bottom of the undercarriage from trhe T.E.
In order to help matters along I needed a 3 ft long extension for each servo that leads to a "Y" . The THROTTLE servo is located mid- fuselage as close to the ROSSI .81cc motor as I can get it. The steering is in a servo up close to nose wheel. (FIXED RUDDER)
POWER SUPPLY is - right now - 4.8 V @ 700MA. Can go up to 6V @ 1400MA
There is a JR 600 SPORT for the TX and a HiTEC RX. All servos are JR but two of them that are HiTEC.
ALL extension connections are housed in a "snap-closed" plastic box designed to keep the two plugs together.
LED landing light in the nose gear area with a separate PC board being powered from the RX.
I hope this helps out a bit.
marwen1
