RCU Forums - View Single Post - GP .60 Reactor Bibe
Old 09-14-2009 | 11:09 PM
  #61
jpjamie
Default RE: GP .60 Reactor Bibe
This bipe has 8 4-40 x 3/8" Philips screws that screw into 8 blind nuts, 4 per strut. There's also a nylon bolt on the top wing to the center pylon as well as 2 nylon bolts on the bottom wing. The instructions strongly suggest using locktite(sp) on the Philips screws (strut fasteners) before every flight. This is lame, but how long does this take to do? I may need to do at least half of these at the flying field because my vehicle is not wide enough for the wingspan. Also, has anyone thought of using another way to fasten the the struts to the wings, like pins with (cotter) retainers? Using pins with retainers would avoid the nightmare of strut screws loosening and messy locktite. Engineers probably thought pins would not provide as "tight" a fit for the struts, but it can be done. I know details, but often the source of problems is a lack of attention to details.
