Assembling Swashplate and AUGH!!! :-((
Miniboy is right on the money. Grease on the bearing races will help keep the balls from running away from you during assembly. It does indeed sound like you did not have the holes lined up…
For your questions:
(These first two both assume you are holding the inner swashplate race stationary with a paperclip from underneath as instructed by the excellent manual, which describes everything below very well)
-When you screw the outer race of the swashplate on, keep turning it gently by fingertips until it contacts the balls and stops. Do not try to tighten this down. You can back it off and recheck your feel several times if you want. Remember, just until it stops. I tighten mayonnaise jars down much much tighter.
-Lining up the holes happens before checking how free the swashplate spins, so I will address that first. You should be able to look through any of the 3 bolt holes in the outer race and see the corresponding bolt holes in the inner race. If you see no holes, unscrew the outer swashplate until you can see the holes line up. This will at most take 1/8th of a turn. When the inner and outer holes are lined up, put a ball on a screw and thread it in BY HAND. Again, these threads are so well machined, it should just twist right in. If you encounter any resistance or the screw stops half way, the holes are not lined up. When the inner and outer holes are lined up properly, the bolt and ball will screw all the way in until the ball is held between the bolt head and the outer swashplate race.
(Now take the paperclip out of the hole in the bottom of the swashplate)
-Once you have one bolt/ball screwed all the way in, turn the two halves of the swashplate back and forth by hand. The bearings will not freewheel due to all of the grease, but there should be no gritty feeling or any binding. Also there should be no vertical play between the two halves. Quite honestly I have done this perhaps 8 times on several swashplates and each time the very first (tightest) set of inner and outer swashplate holes to line up provided very smooth swashplate rotation.
After you get to this point, keep following the excellent instruction manual. Put thread lock on the threads of two more bolt/ball combos and screw them into the other holes (which will obviously be lined up by default at this point). I can not give you an exact torque for these bolts as I do not have a torque meter that small. I would say about 100% of what I give it using the short end of the wrench without making my tumb bleed. I actually use the long end of the wrench, but could snap the screw off at 100% of that making a description for you more difficult. Don’t forget to back out that first bolt/ball and reinstall it with threadlock.
Let us know how things go for you.
For what it is worth,
Spiro
