RCU Forums - View Single Post - Engine
Thread: Engine
Old 06-30-2003 | 07:31 PM
FatCat
Default Engine
I think you might be a little confused as to the terminology you are using. Ringed refers to a ring on the actual piston skirt to aid in compression. And ball bearing refers to the type of bearing on the end of the crankshaft. An engine can be either ringed or non ringed. And ball bearing or bushing for the bottom end. :rainfro:
