RCU Forums - View Single Post - possible a bad reciever
Old 09-16-2009 | 08:22 AM
dignlivn
Default RE: possible a bad reciever
Need more info,
Sounds like you are not arming the Esc.
Remove the prop to be safe.
Plug in the esc with throttle stick Down.
You should hear a beep, now raise the
throttle stick to full Throttle. Should beep
again, now lower throttle stick. You should
hear a serie of beeps (3or4) depending on
your battery size. The Esc should be armed
now.?? Slowly raise the throttle stick, motor
should run.
Bob
