RCU Forums - View Single Post - Paint jobs help and advice
Old 09-16-2009 | 11:56 AM
  #52
xpresssi
Default RE: Paint jobs help and advice
I almost forgot,
Make sure you spray your edges & hard to get areas first let them flash, then spray your project using a stedy left to right motion. When you start to spray make sure you pull your triger off of the the project then holding untill you are off of the project then let go. Starting from the left side pull triger hold with steady gliss to the right side. When the gun is no longer over the project then let off of the trigger. the gun should be held 6" away from your project & it contours as you spray. Hope that makes since to you.
