RCU Forums - View Single Post - GP RV-4 - How did you mount your receiver and battery?
Old 09-16-2009 | 10:45 PM
Pitts532M's Avatar
Pitts532M
Default RE: GP RV-4 - How did you mount your receiver and battery?
<div style="margin: 0in 0in 10pt">This was my first build after nearly twelve years away from the hobby and twenty building. I enjoy the plane and it has north of 50 flights on it.O.S. 46 AX, Pitts Muffler, switched over to 2.4 radio after I had flown the plane for awhile. I had added an antenna sleeve that took the antenna out the tail, it is clear colored; you can see it in the photos.Flaps with Go Slo added, does make the radio installation tight and interesting getting balance correct.Plane is Monokoted with fiberglass painted cowl.Added a more scale tail wheel. Plane flies great, is fast, flaps make it a floater on landing. I do routine aerobatics and an occasional snap-roll and spin with the plane.</div><div style="margin: 0in 0in 10pt">Hope this helps&hellip; </div>
ID:	1276848   Click image for larger version
ID:	1276849   Click image for larger version
ID:	1276850   Click image for larger version
