RCU Forums - View Single Post - Flair Puppeteer Build
Old 09-17-2009 | 09:46 AM
cymaz's Avatar
cymaz
Default RE: Flair Puppeteer Build
So Hols are over and I have almost finished the starboard lower wing. As you can see I will not sheet until the wings are mated and glued, I want to make sure the bracing slides in good and there is plenty of epoxy all round the main structure. Before that wing join I will cut out the ailerons from the wing....it should be easier with 2 halves.
Here's the progress.........
ID:	1277022   Click image for larger version
