Guys ..... just test fly my 110 this evening . Wow , i must say that the Scropion 4035 250kv is a kick axx power house ..... !!
Before i take it to the sky , i check with Watts -meter showing that with 18x10 APC-E 77amp n 2600w on the grown , i think that
the reading amp is higher than 4035-250 statedbeing 65 amp MAX continue , so i prop it down to 17x10APC-E and getting 63amp n
2400w , i just go with the 17x10 for the safe side not to burn the motor ........ Oh yes , i am using 10s setup 2x 4900mah 5s Rhino20c.
I managed to get 4min flight time only , as the rain is coming soon .... not much triming have been done , just fly it and see how the
4035-250 handle the 110 , well power is well OVER !! you can go vertical with about 70% "still have 30%" power left to spare if you
need it . . . . just do some simple p-09 menuever...... i like the snap very much"with low rate" the plane snap well and stop when you
release the control stick n it stay on the line !
Landing is most interesting , i think it land easier than my Angle 50 .... it still feel "FLOATY" with 10s setup with 4350 g ...... just turn
and come in with a three point landing 'nose up abit' , really nice !!!
Will fly it tomorrow evening again and do some cg check and triming .....
