Solder issue.
Hi,
I'm finishing to build my SIG Somethin' extra and the manual tells me to solder the brass coupler onto one end of the braided throttle cable. I did it but it seems that my solder is not strong enough as it broke when I connected it to the throttle and did some tests . I used Silver solder to do it. Do you have any tips to make a strong solder. Or should I use another system to connect the servo to the throttle...
Thanks.
