RCU Forums - View Single Post - Solder issue.
Old 09-18-2009 | 03:24 PM
big max 1935
My Feedback: (9)
Default RE: Solder issue.
You want to put solder on the cable back so it will be stiffer where it comes out of the plastic tube . Put a little flux on the cable & put it in the coupler & put your soldering iron on the coupler & heat it, add your solder where the cable go in ,you will see it flow in the coupler . It won't come out then . Good luck , MAX H.
