RCU Forums - View Single Post - NEED DB's SOUTHERN SORGHUM
Old 09-18-2009 | 07:50 PM
dhal22
Default RE: NEED DB's SOUTHERN SORGHUM
when i saw how far polyurethane glue expanded into my foam wing cores i was hooked. the amount of glue it takes to sheet wings is so little all it has to be is a glossy shine on the cores and that's it. the glue will expand 1/4" into the foam if the wing assemblies are clamped thoroughly. vacuum bagging would have similar results i suppose.
