RE: Stuck aileron
There is a good chance that one of gears in the servo has been stripped. That type of damage can be caused by a crash or if the control surface has been bumped which applies too much pressure through the push rod and control horn to the servo causing the travel to exceed the normal range of the servo resulting in the gear(s) to strip.
