RCU Forums - View Single Post - Need help with an O.S. .61 RF
Old 09-19-2009 | 11:28 AM
TFF
Default RE: Need help with an O.S. .61 RF
You are either going to have to run a pump or close it off. The pressure in the crankcase has to be high enough to not only push the fuel through the ports of the engine; it is now having to make up the volume in the tank as the fuel goes down to push the fuel forward. You want a pump.
