RCU Forums - View Single Post - Heli interference question
Old 09-19-2009 | 12:38 PM
jw637362's Avatar
jw637362
Default RE: Heli interference question
Well, went to the local radio shack - Picked up a Ferrite ring. Got that on the Speed control right before it goes into the receiver. Took the rudder servo and "coiled" the wire and had it go to the other side, reducing that length. Remaining wires behind the frame above the gyro.
Took fuel tubing and have that inside the frame for the antenna to pass through so it is not touching any metal inside and re-routed it out.
Coiled it around the antenna tube to reduce length and then pass-through to the back again.
Cleaner now.
Took it out in the driveway and hovered with no apparent interference problems.
Thanks for the help.
