RCU Forums - View Single Post - Need help with thunder tigre 4 stroke
Old 09-19-2009 | 01:10 PM
estradajae
Default RE: Need help with thunder tigre 4 stroke
Yes, there is an active thread about it.
But the engine runs indeed good despite this problem. After i solved the problem the engine ran better, but it was running good
To Rodestar99,
you can't blame an engine just because it doesn't work for you, mine runs very well, and it has run very well to other people. You may have gotten as well a lemon or an engine with really something bad. How much fuel does it have run, what is your setup, what fuel are you using? Check the cam timing (the dot should align with the pushrods at TDC). Is it well run in?? After about 10 litres of fuel my engine came to life.... post some pictures and what you have there, maybe we could help you.
Saludos,
Jorge
