RCU Forums - View Single Post - ff9 ????
Thread: ff9 ????
Old 09-19-2009 | 05:58 PM
RogerParrett
Default RE: ff9 ????
Beef,
During the week Bax / Krysta would jump right on this. But since its the weekend and you may be anxious to fly, try this quick solution using mixes:
FIRST MIX
PROG.MIX1 page 2/2
MIX->ON
MAS->OFST
SLV->6:FLAP
LINK->OFF
SW->C
POSI->CENTER
PROG.MIX1 page 1/2
(ON or OFF, depending on current SW-C position)
(OFST->FLAP)
RATE->30% This is a guess for the mid position
END END (to escape to main screen)
SECOND MIX
PROG.MIX2 page 2/2
MIX->ON
MAS->OFST
SLV->6:FLAP
LINK->OFF
SW->C
POSI->DOWN
PROG.MIX2 page 1/2
(OFST->FLAP)
RATE->80% This is a guess for the full position
I checked this in the Servo Monitor and it works reasonably. REMEMBER, you may have to set the percentages to negative values, or do a servo reverse depending on the movement of the flaps during test.
Also, note the the VR(A) dial can also "tune" the flaps in the default setup, but you can deactive that by going to AUX-CH option in the BASIC(ACRO) section and setting CH6->NULL.
Enjoy your Futaba 9CAP Super. It is a fantastic radio!
Best Regards... Roger Parrett / Dayton, OH
