RE: Need help with elevator only glitch while engine is running.
make sure the system wiriing is as for away from the igintion as possible......what kind of throttle clevis are you using on the engine? use plastic somewhere. Do you get glitches with ignition on and engine off?.....and lastly you are using 2 seperate switches 1 for the system and 1 for the ignition. hope this helps as it is a start.....
