RCU Forums - View Single Post - Help after crash!
Old 09-20-2009 | 10:25 AM
stang
Default RE: Help after crash!
Don't turn the engine over! Gently brush or pick away all the dirt you can see. Inspect the outside of the engine for cracks or other damage. I would take off the carb and soak it with water to get the remaining dirt out. I then would take rearplate off the crankcase and the head of the engine and flush with Varsol or WD-40 then inspect the inside of the engine. Only after you are sure the dirt is all removed would I oil up the engine, re-assemble and start it.
