RCU Forums - View Single Post - cpv3 pinion
Thread: cpv3 pinion
Old 09-20-2009 | 05:48 PM
CarGuy7a
Default RE: cpv3 pinion
I looked at my CPV3 again and you're right there isn't one. For some reason I thought I took mine off when I crashed and did a rebuild but I guess I didn't.
It's probably pressed on like the tail rotor. If your new BL motor has a flat spot on the shaft to accept a grub screw style pinion I wouldn't worry about getting the stock pinion off and re using it. I think the gears on the CPV3 are 48 pitch, so you'd need to find what the new motor shaft diameter is in mm's and then get a pinion that will fit.
