RE: Servos
you can mix and match servo's, about the only thing different with futaba from other servos is a little tang that sticks out on the side of the connector, but you can cut this off or shave it off to fit with other servo extensions or recievers. And reciever battery brand doesnt matter either, just as long as its a 4.8v or 6v and the proper Mah needed.
