brushless upgrade question
I have a Exceed j3 cub. I want to upgrade it to brushless so i can fly it with out using full throttle for the entire flight and i want it to have power enough power to do whatever i want. This is what I'm thinking of putting in it from an exceed Alpha 400 (920kv) brushless motor, 30A Electronic Brushless ESC Speed Controller [Volcano Series],Capacity:1750mAh Constant discharge: 20C Burst rate: 30C (15sec) Configuration : 3S 11.1v Pack size: 93x33x22mm Weight : 155g lipo battery. I know I will have to modify the plane to make the motor and battery to fit, but will the motor esc and battery configuration go together well? What prop should I go with for this set up? Let me know I want to get this stuff on order asap.
