RE: Need help with elevator only glitch while engine is running.
Just had the same problem this summer, it was the switch. This was one of my own planes. Have one of my friends planes in my shop with glitching ailerons, it was a bad Y-harness. Replacing the switch cured my problems and it was an easy trace. Just unplug the battery and install it directly into the RX to bypass the switch and see if that doesn't cure your problem.
