RCU Forums - View Single Post - H9 Edge BME 44 or Saito 180?
Old 03-31-2002 | 07:13 PM
Turbobruce
Default Thanks John
Thanks for the reply John, I feel much better now!!!
I have begun bulilding the edge and I must say this plane is a beauty!!!! John do you have any pics of your edge showing the servo install or the bme mounted on it? I 'm thinking of using duralites for the ignition and reciver pack to conserve weight. I hoping to come in at 13.25 to 13.50lbs. I'm also going to install the fuel tank sideways to get it
back as close to the CG as possible. I will have to reposition the throttle servo but it does not look to be a problem. Please keep me updated on your edge and I will do the same.Ohh what did you use to reem out the prop and the spinner for the BME? The shaft is bigger than my other motors. Thanks for the help.
Bruce
