RCU Forums - View Single Post - Thrust Stand
Thread: Thrust Stand
Old 09-22-2009 | 01:08 PM
arobatx
Default RE: Thrust Stand
When we've needed/wanted to play with one, we made it. Ball-bearing supported mounting plate, pulling against the most accurate fish scales we could get ahold of. Even though only remotely accurate, we thought we would benefit mainly from the difference in thrust from prop to prop tested. We learned quickly however, that static thrust numbers mean little when you try to apply your findings to dynamic flight characteristics. The thrust test stands have sat idle pretty much ever since.
