RCU Forums - View Single Post - Screaming Demon big block bash
Old 09-22-2009 | 02:51 PM
RVman
Default RE: Screaming Demon big block bash
Yeah, the next issue I had to figure out was the needle valve since it would end up inside the wing.. Thought about it for hours and then finally the light came on. I simply made a plug for the hole and will just use a remote valve mounted somewhere else. You probably have the same thing with the OPS?
Tom
