Emergency shutoff
I'd make sure the pump lost power too. The solenoid could stick or get some dirt in it. That's why I suggested removing all power to the ECU. I would put the switch in the pump power leads if you want to keep the ECU on.
I will leave the Jetcat guys to comment on what would happen if you interrupt the solenoid or pump power and leave the ECU running.
