RE: Top Flite Staggerwing
Iceman..............
When you ran the blue perry pump, did you also run a tee in the fuel fitting (bypass line)
I know you ran one so you could feed both carbs but
you didn't do the fuel bypass line that some use when the fuel presure is too
high and you have to reduce the needle setings too much...???
Thank you
Justin..
