RCU Forums - View Single Post - How hot does the ignition module get?
Old 09-23-2009 | 01:20 PM
arobatx
Default RE: How hot does the ignition module get?
ORIGINAL: leedees
I am using the stock ignition module with the Zenoah G20. The angle of the fuel inlet on the carb is such that the fuel line will rest against the front of the ignition module.
Will this cause any problems, i.e. too hot for the fuel line etc?
The inlet nipple on your carb is a press fit. Though it is snug, it will move. You can turn it to better suit your installation. Just be careful, the plastic on the OEM inlet nipples can crack, grab and turn it at the base, not the bend.
