RE: Fascination 50 ARF available
I have one with a Magnum .52 in the nose. Mine is a little bit different. i do not have the bell crank in the middle for elevator. It uses a split push rods.
I had issues with the markings on the fire wall. They did not line up with anything. I set the engine up so it was centered with the opening in the cowl.
I found the instruction to be great. I used them to mix my epoxy on. I had enough sheets to build the whole plane without using anything but the instructions for a mixing area.
Mine flew nose heavy at the listed CofG. I moved it back almost 1/2 inch.
Dru.
P.S. I got mine from Nitroplanes.com
